AutoCAD Civil 3D General Discussion
*Expert Elite*
326 Kudos
Post 11 of 15
Re: Irregular grading issues - Please Help!!!
10-28-2013 09:27 AM in reply to: jmayo
Excellent point. define the pad at 190 and grade to toe
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Valued Contributor
2 Kudos
Post 12 of 15
10-28-2013 10:18 AM in reply to: Postmaster_G
I like to create points at a slope/grade elevation, then add the points to the surface and regen.
Valued Contributor
3 Kudos
Post 13 of 15
10-28-2013 12:52 PM in reply to: g_k50
Thank you all for your advice!
I'm not sure what you mean
Valued Contributor
2 Kudos
Post 14 of 15
10-28-2013 01:03 PM in reply to: Postmaster_G
Instead of using polylines I create points that have an elevation and a X, Y position.  When creating points you can select the method of creation to be along a direction and a distance, the new point will be created at a certain elevation from the start point depending on how far away it is from the start point and the grade/slope desired.  The new points that are created in this manner can be added to the surface definition to fill in the contours without the problem of overlap and crunching found from using a grading object.  It's old school way of doing it, doing it by hand sort of.
Valued Contributor
2 Kudos
Post 15 of 15
10-28-2013 01:05 PM in reply to: Postmaster_G
createpoints at the command line
sixth icon from the left drop down menu
Post to the Community
New Post
