albionpjl,
If you have created the surface, the surface style controls the visibility.
As James stated, select the Surface from prospector, Rt. Click, Properties.
On the information Tab, you should see the "Standard" surface style. Select
the drop down next to the style and select "Edit Current Selection". On
the style dialog, select the display tab and make sure the surface border or
contours are toggled on.
If this does not work, the layers may be off. The surface object is
assigned a layer when the object is created. Make sure the Surface layer is
not off.
Lastly, the surface point data may not have been added correctly. To
create a surface from a point file, you need to first create the surface and
then add the data. Therefore, select Surfaces->Create Surface from the
menu and give the surface a name. Next, find the surface in Prospector and
expand the surface so that you see the definition node. Lastly add the point
file. After the surface builds, select the surface properties, and check
the surface statistics to make sure data was added.
Daniel Philbrick
Autodesk, Inc.
"albionpjl" wrote in message
news:4157729.1099473373496.JavaMail.jive@jiveforum2.autodesk.com...
> Nope, didn't work.
> I still on;ly have 'Standard' style and an invisible surface.
> It is possible that my surface doesn't have any objects in it. i followed
the instructions in help for creating a TIN, but it doesn't say how to tell
it what to make the TIN from (ie which point group). Does it just use all
the points? Do I have to select some first? Am I just missing something
idioticly simple?
