Member
sdrobs
Message 1 of 8 (266 Views)
Invert Contours (Positive Elv to - Elv)
266 Views, 7 Replies
04-10-2012 11:48 AM
I have a contour map that i need to flip all the postive contours to negitive. So the Z cordinate for example is Elv 40 now i need to invert it to -40. I want to do this to the whole large contour map. ????
Shawn
Alfred.NESWADBA
Message 2 of 8 (264 Views)
Re: Invert Contours (Positive Elv to - Elv)
04-10-2012 11:50 AM in reply to: sdrobs
set the UCS to look from the right side (or from front) and then mirror your contours.
- alfred -
Alfred NESWADBA
Distinguished Mentor
thepworth
Message 3 of 8 (250 Views)
04-10-2012 12:59 PM in reply to: sdrobs
is it contour data or contours representing a TIN/DEM?
If its contours as CAD objects, you could use the Map3D side of C3D to perform a drawing query to multiply all contours by a (-1) value and then recreate the surface.
I'm not a fan of surfaces from contours w/o the breaklines.  The software has gotten better, but there's still a loss.
The miserable brute-force way would be to export to xml and then replace the elevations with a "-" character.  dunno even where to approach that
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
Member
sdrobs
Message 4 of 8 (231 Views)
04-10-2012 03:30 PM in reply to: sdrobs
Thank you, i will give that a try.
BrianHailey
Message 5 of 8 (222 Views)
04-10-2012 04:11 PM in reply to: sdrobs
Create a surface from the contours (do all the minimizing flat area options, you can read why HERE) if it's not already a surface. Create a flat surface at elevation 0 that's totally encompasses your surface. Create a volume surface that compares your surface as the base surface and the 0 surface as the comparison surface. Have the volume surface display contours. Extract the contours from the surface (if you don't want to have the surface).
Brian Hailey
CAD-1.com
My Blog
Member
sdrobs
Message 6 of 8 (221 Views)
04-10-2012 04:14 PM in reply to: sdrobs
Thank you so much, that worked.
Shawn
thepworth
Message 7 of 8 (210 Views)
04-10-2012 08:49 PM in reply to: BrianHailey
Guess I was having a "blonde moment" when I didn't think of that one ealier - nice!
C3D 2011
BrianHailey
Message 8 of 8 (198 Views)
04-11-2012 07:27 AM in reply to: thepworth
It's a technique I used to use in LDT to help delineate watershed boundaries, create an inverted surface and use the water drop tool on it.
Brian Hailey
CAD-1.com
My Blog
