Civil 3D Forum
Inversing
6 REPLIES 6
667 Views, 6 Replies
Inversing
Can anybody explain this process? I fail to see the cogo button in my Draw panel? Using Civil 3D 2014.
http://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/documentation/CIV3D/2014/E...
I'm trying to create a points inverse report without creating a polyline, then using the Load Traverse from Polyline into the Coordinate Geometry Editor which then shows the inverses between points. I like to see more random inverses - point to point - point range etc.
6 REPLIES 6
wfberry
I see what you mean.  Try changing your Workspace settings from Civil 3D to Planning & Analysis.  You should see the COGO dropdown there.
Bill
in reply to: wfberry
Thanks Bill. I do see it. Any attempt to hit a button OR type in the
appropriate command yields "Unknown command"? Seems the Map functions are
not within Civil 3D?
Cheers:
Donald Nordstrom
DNN drafting 11701 87 Street
Grande Prairie, AB T8X 0H3
PH: (780) 897-3488 nord@telus.net
jmayo-EE
There is also the Inquiry Tool on the Analysis tab that will do point inverses. Don't know if you will get that to the Mapcheck Tool for a travese segment though...
John Mayo
rkmcswain
AFAIK, any "map" functions/commands that are duplicated by something in Civil 3D are left in an inaccessible state (such as you have found), so that KB article may be accurate but only for Map 3D, not Civil 3D
R.K. McSwain     | CADpanacea | on twitter
in reply to: jmayo-EE
I can only Inverse between two points at a time only? I don't see where I
can enter a point range? Have not used the Mapcheck Tool before. Is that a
Map feature again?
One more wish would be to generate a station and perpendicular offset report
showing points along an existing alignment?
Cheers:
Donald Nordstrom
rkmcswain
You can do that.
Toolspace > Toolbox > Reports Manager > Points > Station Offset to Points > Right Click and Execute.
Export it to Excel so that you can sort on your desired column (no sorting options in the command itself)
Rail Community
