Civil 3D Forum
Invalid input message trying to create curve between two lines (Civil3d2009)
2 REPLIES 2
458 Views, 2 Replies
Hi there:
I am receiving an invalid input message when trying to create a curve between two lines. My drawing  units are set to architectural. The problem is summarized as follows:
 1- In Lines/Curves menu, select curve between two lines.
 2-Select first tangent
 3- Select second tangent
 4-Select radius option
 5- Enter 8'6"
 6- After entering the radius I receive an invalid input message.
 7- But if I enter the radius as 102 (102 inches) the curve is created without any problem.
What am I doing wrong? Can anybody help me, please?
2 REPLIES 2
tcorey
Civil 3D is meant to work in decimal units, so it does not understand the foot symbol. Like you said, if you give it a radius as the number of inches, it works. That's because you aren't using ' . Oddly, you can input the inch symbol. Maybe because it's at the end of the input it gets ignored.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
rkmcswain
I suspect it's because the Civil 3D programmers for this command did not anticipate anyone working in Arch units.
In this particular case, you may be able to use the Fillet command which will accept 8'-6"
R.K. McSwain     | CADpanacea | on twitter
Rail Community
