Civil 3D Forum
introduction questions about using AutoCAD Civil
2 REPLIES 2
274 Views, 2 Replies
I need your help to check my answers
Q\When can an alignment subdivide a parcel?
A)When they are in the same site
B)When the parcels are ROW parcels.
C)When they are part of the same drawing file
D)When it is a design style
I think the correct answer is A
Q\How do you open the Alignment Layout Toolbar in an existing alignment?
A)Go to Home tab>Create Design panel & choose Edit Alignments
B)Select Alignments in the Prospector tab
C)Right click on Prospector and select Alignments
D)Select the Alignment in the drawing
Q\ A profile view may be relocated by using the ACAD Move command
A) True
B) False
I think the correct answer is B 'False'
Q\How is the width of a lane within a corridor model changed?  (select all that apply)
A)Subassembly Properties
B)Advanced Properties
C)Assembly Properties
D)Corridor Properties
I think the correct answer is A, C and D
Q\In Create Intersection Wizard which tab is used to set the Curb Return Parameters?
A)Corridor Regions
B)Geometry Details
C)General
2 REPLIES 2
ToddRogers-WPM
in reply to: 985858485
A) True
B) False
A)Corridor Regions
B)Geometry Details
C)General
Todd Rogers
Joe-Bouza
B)Select Alignments in the Prospector tab>> RC "Se'ect">>edit geo
A) True
B) False
D)Corridor Properties: if target controlled
A)Corridor Regions
B)Geometry Details
C)General
Your Name
Your Name
Rail Community
