Good day All,
I would like to know how it would be possible to manipulate the Intersection Wizard so that I can obtain the required shape as drawn by the architect. In essence create a "round about" shape. Please see the attached image for furhter detail.
Your assistance in greatly appreciated.
Regards
Ryan
Well I'm going to be a bad influence here, but if you can't get it to work using the "Create Roundabout" function (which, frankly I haven't toyed around with enough to learn), you can cheat.
Instead of two alignments and one Roundabout intersection, you can make a circular alignment (that's jjuuuust closed) at the edge of the center island and make the two roads as four separate roads. This gives you 4 separate intersections to manipulate. You'd have to make a new assembly of course for the rotunda.
However a very, very big DISCLAIMER: this is kind of brute force (read: most probably not good practice) method to create a roundabout which we here at the office did because the last time we had a roundabout in the master plan the deadline was too close for us to figure out the "Create Roundabout" command.
This will help.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Your Name
Your Name
