Ok, I have a simple corridor with a primary road and several intersecting secondary roads. The primary road has the crown maintained. I am using left & right gutter (flowline) alignments to control the roadway width of the primary road. I do have design profiles for these left & right gutter alignments which I am attempting to use as elevation targets in my intersection design. The problem I am having is when I use these left & right gutter alignments for width & elevation targets for my curb returns…..the corridor is not modeling correctly along the gutter line through these intersections. Instead of being a constant grade through the intersection, it triangulates in a vertical zig zag fashion. Any help would be appreciated.
C3D 2014
I would triple check the targeting of the returns, and the side road pgl equalities at the edge of the main road. Personally, when I do those, I model the main road, estract the eop FL, make separate corridor for the side roads targeting the eop fl, etc. Then paste the surfaces together
Joe Bouza
I have run into this problem as well.
I have found it better to sperate your curb return corridor into 2 regions targeting the approprite road widths and elevations than have 1 region with mutiple targets. I beleive it makes for a cleaner drawing as well.
I have also found that the surface triangulation tends to mess this up too. Have a look and maybe swap a few lines around.
I agree with Joe. I've always created a corridor for the main alignment, created a dynamic feature line to that main corridor feature. Then target to that featureline from the curbs (those are set as you've noted with alignments and design profiles). If you have profile set for your targets on the main alignment where you have jagged faces that is likely the reason for what you're seeing. Just use the featureline as the target and this should blend this nicely. You'll also want to set a frequency point at the middle point where one CL meets the target FL of the main alignment. to have that triangluate properly. Good Luck.
