I have created an intersection using the wizard as I always have.
I have redrawn the drawing twice already and i cannot seem to get this corrected.
Could someone please explain to me the solution to the problem in attached image.
I am not sure what i see in ur screen shot. But its obvious that some of ur corridor targets are in 0 elevation, try to check what ur assembly regions are targeting, Check feature lines and profiles are they ok
Hey Aistis,
Yeah the surface seems to be targeting to 0 elevation. I have checked assemblies, but i don't think the fault lies there.
It seems as though the curb return aligments are sitting at o elevation and not matter how I change the assemblies, it just keeps creating these holes in the corridor surface i.e. 0 elevation.
I am at wits end, really.
Have you checked curb return alignments? do they have profile's ? I had similar problem , my curb return alignment had two profiles , so corridor did not knew what profile to use. Plus are you using standard civil 3d assemblies? or are you using your own subassemblies?
You should create profile view of that curb alignment and fix elevations with profile creation tool. And after you do it go to corridor properties and in parameters just give direction of that profile and alignment
