Please if some one can help us regarding attached file
Create alignments / feature lines representing back of footway etc then target with corridor model.
You can specify this when you create an intersection I think. Sorry I dont use the intersection command as it will not do what I need it to. I find it simpler to design using laignments the old way.
"Secondly we can build the back of walk with a simply feature line connecting the back of walk with the row line"
This will not be dynamically responsive to elevation changes of the intersection.
I would horizontally Target the 2D polyline linework of your sidewalks with the PCR Assemblies, or design and implement a correct PCR assembly for your conditions.
