Civil 3D Forum
Intersection of level plane and surface
4 REPLIES 4
tthurston
1176 Views, 4 Replies
How would you show a intersection line showing the intersection of a surface and a level plane or level surface?
Intel Core 2 E8500 @ 3.16Ghz
RAM 8 GB
64 bit
Windows 7 Enterprise SP 1
ACAD Civil 3D 2011
4 REPLIES 4
BrianHailey
in reply to: tthurston
Surface Properties -> Analysis tab. Perform a "User-defined contours" analysis:
http://screencast.com/t/fjAFMeJjdh
Then set your surface style to display you user contours:
http://screencast.com/t/TnazEdLiN2
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
neilyj666
in reply to: BrianHailey
or use the MinimumDistBetweenSurfaces (works best in 2012/2013)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
BrianHailey
in reply to: neilyj666
I always seem to forget that command is available.
GEI Consultants
My Civil 3D Blog
neilyj666
Yes - the contour method as described will work best on a volume surface where the 0 contour line is the user defined one
Rail Community
