I cant seem to change the display or size of the intersection marker. is this a known issue?
Solved by Jeff_M. Go to Solution.
Thanks Jeff
I must be editing in the wrong place. This is what I changed.Is there a different setting to adjust?
Close but wrong tab.....
Don Ireland
Engineering Design Technician
Hmmm. I wasn't able to change the size on the display tab -- but I could turn it on/off, change color etc.
Don Ireland
I think I am? I tried the light bulb, size, a blank marker, I'm flummoxed.
Point you have highlighted (which I'm assuming you're using) is BLANK which doesn't show at all. Have you tried selecting the X or +? And using either of those, have you changed the size in the uppper right corner?
Don Ireland
Interesting: it doesn't react to changes in the prospector settings tab, but if I grip and RC the marker it reacts to the lightbulb getting turned off. Thats wierd. Well now I am really puzzled! I go back to the marker style in the prospector an the light is on but they are off in the drawing. Where is the marker definition stored?
What-a-Maroon!
Let that be a lesson to you Bouza: back up and relax before you panic!
Thanks, Jeff
