Civil 3D Forum
Intersection Marker style
12 REPLIES 12
Message 1 of 13
Joe-Bouza
378 Views, 12 Replies
I cant seem to change the display or size of the intersection marker. is this a known issue?
Your Name
Your Name
12 REPLIES 12
Message 2 of 13
Jeff_M
in reply to: Joe-Bouza
I can change the style & size in 2012 & 2013 without a problem, Joe.
Jeff_M, also a frequent Swamper
Message 3 of 13
Joe-Bouza
in reply to: Jeff_M
Thanks Jeff
I must be editing in the wrong place. This is what I changed.Is there a different setting to adjust?
Your Name
Your Name
Message 4 of 13
Jeff_M
Yep, that's where I'm editing it. Are you editing the correct style?
Message 5 of 13
doni49
Close but wrong tab.....
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 6 of 13
Jeff_M
in reply to: doni49
Not really, he asked about display and size. So he showed one, you show the other...either way, I can edit all of these.
Message 7 of 13
doni49
in reply to: Jeff_M
Hmmm.  I wasn't able to change the size on the display tab -- but I could turn it on/off, change color etc.
Don Ireland
Message 8 of 13
Joe-Bouza
in reply to: Jeff_M
I think I am? I tried the light bulb, size, a blank marker, I'm flummoxed.
Your Name
Your Name
Message 9 of 13
doni49
Point you have highlighted (which I'm assuming you're using) is BLANK which doesn't show at all.  Have you tried selecting the X or +?  And using either of those, have you changed the size in the uppper right corner?
Don Ireland
Message 10 of 13
Joe-Bouza
in reply to: Jeff_M
Interesting: it doesn't react to changes in the prospector settings tab, but if I grip and RC the marker it reacts to the lightbulb getting turned off. Thats wierd. Well now I am really puzzled! I go back to the marker style in the prospector an the light is on but they are off in the drawing. Where is the marker definition stored?
Your Name
Your Name
Message 11 of 13
Joe-Bouza
in reply to: doni49
none of that changes anything from the prospector. RC in plan works.
Your Name
Your Name
Message 12 of 13
Jeff_M
Joe, in the image you showed the style highlighted, it appears that you are scrolled way down....are you possibly editing the style in another open drawing?
Message 13 of 13
Joe-Bouza
in reply to: Jeff_M
What-a-Maroon!
Let that be a lesson to you Bouza: back up and relax before you panic!
Thanks, Jeff
Your Name
Your Name
Rail Community
