Hi all,
I have an issue with the above which i am having real trouble solving. Please see the screenshot below which is fairly self explanatory.
You will note that the curb return fillets are forming on the inside of the radius rather than the outside. The daylight is then shooting off back across the radius! It doesnt matter which subassembly i use, it always ends up like this!
Is there something simple that i am missing in the setup which is causing this?
Many thanks for your wisdom in advance!
regards
Solved by kcobabe. Go to Solution.
More than likely you will have to flip your assembly or reverse your alignment.
You can also ad more than one target, which need to be done on intersections with a crown on both roads. I typically no longer use a profile for intersection targeting as it's much easier and a more on the fly kind of thing to use a feature line. Of course most people still use alingments and profiles.
Very simple in the end, I just mirrored the assembly of the kerbline and its flipped it over on the plan!
Thank you!
No problem. I know that drove me nuts on my first intersection corridor. Glad I could help.
