Two options:
1. Use a corridor that daylights with an almost flat projection. Works OK
until you get into the bowtie areas.
3. Use a corridor with flat links that will extend out beyond the surface
interface. Create a surface from this, then run a volume analysis. Then draw
only the user defined contours and set only the 0 contour to show. Then
explode the volume and you have a polyline. Project that onto the EG and
you'll have your floodplain.
How's that RAS tool working out for you?
James Wedding, P.E.
Engineered Efficiency, Inc.
Civil 3D 2007
XP Tablet, SP2, 2GHz, 2G
www.eng-eff.com
www.civil3d.com
