Civil 3D Forum
Intersect Surfaces
5 REPLIES 5
sdevin
336 Views, 5 Replies
Intersect Surfaces
I have a water surface profile along a river from which I have created a C3D surface. I would like to intersect this surface with the existing grade along the channel bank to define the floodplain limit using a 3dpolyline I suppose. Is there any way to do this. I have tried creating a composite surface by pasting each surface but this didn't work. My water C3D surface extends under a portion of the existing ground surface and I would like to clip this portion.
Steven C. Devin, P.E.
Consulting Engineer
Civil 3D 2007 SP3
Dell Precision 670
Dual Xeon 3.2 MHz
3 GB RAM
Nvidia Quadro FX3400 256MB
5 REPLIES 5
in reply to: sdevin
Two options:
1. Use a corridor that daylights with an almost flat projection. Works OK
until you get into the bowtie areas.
3. Use a corridor with flat links that will extend out beyond the surface
interface. Create a surface from this, then run a volume analysis. Then draw
only the user defined contours and set only the 0 contour to show. Then
explode the volume and you have a polyline. Project that onto the EG and
you'll have your floodplain.
How's that RAS tool working out for you?
James Wedding, P.E.
Engineered Efficiency, Inc.
Civil 3D 2007
XP Tablet, SP2, 2GHz, 2G
www.eng-eff.com
www.civil3d.com
sdevin
in reply to: sdevin
The HEC-RAS tools are great! I'm just trying a new way of presenting the data. I was able to essentially freehand the water boundary from the HEC-RAS tools but now I am trying to delineate a boundary that is 1 foot above the flood elevation. I'll give your second suggestion a try.
in reply to: sdevin
If you make the surface then just perform a datum edit, you should get the
1' freeboard line with no more work.
Glad to hear it's working for you.
James Wedding, P.E.
Civil 3D 2007
www.eng-eff.com
www.civil3d.com
sdevin
in reply to: sdevin
I copied my water surface surface and then raised it one foot. However, I am still not sure how to make the new surface daylight into the existing ground. If I were to create a new profile that is one foot above the water surface profile I could perhaps build a corridor as you suggested but this also has problems. My river alignment consists of many segments connected by PI's with no curves. HEC-RAS didn't like it when I used curves. (Each end of the alignment appeared to be connected by a chord.) When I've tried to label offsets with stations and elevations I realized that there a blank areas because of the angle points on the alignment (there are blind zones where there is no stationing except at the alignment centerline.) I haven't made the corridor yet but I really wonder what will happen with these blind zones.
in reply to: sdevin
If you have the surface, use the volume surface technique to get the 0
contour and go from there.
James Wedding, P.E.
Civil 3D 2007
www.eng-eff.com
www.civil3d.com
Rail Community
