Hi everybody,
I wanna interpolate points from surface but only in that area where my sample lines intersecting with the surface. There is a point creation tool that makes this based on polylines but I have to many data and it will get to much time to do this. So, for better understanding I attached some pictures, in the first picture it is showen the final result which I have made based on polylines, but here is also a problem, the tool is not putting points where the surface is changing ( on my second picture I highlighted with red circles).
Can somebody find a solution for my problem?
If I understand what you want you should be able to create feature lines (at the elevations of the points) along those sample lines and add those to the surface as breaklines. This will force triangles to be added at the points you expect. Good luck.
Mark Green
Working on Civil 3D in Canada
There is no command that extract the points from surface automatically, example every 10 m based on my alignment?
Troma your solution is working well, but it takes to much time. How can I make batch commands or similary with batch?
Mark Green
