Thanks for the reply.
The problem is that I need the new pline to follow the downward slope of the surface. It will meander across contour lines to reach the next point. Essentially, I'm trying to follow a flood event line, and all I have is a handful of points with elevations along the sampled sections. If I draw a straight line between points, it tends to cross the river. All of the flood inundation data was created with HEC-RAS, so I was hoping to just use C3D to quickly generate the various flood event lines from these points rather than re-calc.
