Civil 3D Forum
Interoperability 2014 to 2013
14 REPLIES 14
Message 1 of 15
neilyj666
582 Views, 14 Replies
Apparently you can edit Civil 2014 files in 2013 with a few exceptions e.g.pressure pipes
http://www.youtube.com/watch?v=XD1K-5GS02M
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
14 REPLIES 14
Message 2 of 15
troma
in reply to: neilyj666
Sounds like a step in the right direction.
Mark Green
Working on Civil 3D in Canada
Message 3 of 15
Jay_B
Interoperability / backward compatibility is great news!Smiley Happy
Glad to see AutoDesk is adding this much needed option and hopefully this can be expanded it to a minimum 2 releases backward in the future. (Since 2013 was a new file format, makes sense it only works for 2014 working with 2013 files)
This will definitely help the Civil 3D community with project collaboration moving forward.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 4 of 15
ToddRogers-WPM
FINALLY!!!
Todd Rogers
Message 5 of 15
rl_jackson
in reply to: ToddRogers-WPM
Can we here a resounding
"Hooraayyyyyy!!!!!!!!" Smiley Happy
Rick Jackson
Survey CAD Technician VI
Message 6 of 15
mathewkol
Another exception is DREFs.  It will appear as a strandalone object in 2013 which is editable.  Not so good, but how would the code get around this I don't know.  Open the same file in 2014 and the DREF is reloaded from the source file.
This was done becasue  if a DREF is not found in 2014, the object still shows!  Very cool.  It's like the object exists as a standalone object, but if the source file is found it is used.  Obviously, 2013 does not have this feature, so it IS a standalone object.
Still, working in a mixed environment in your own office (2013 and 2014 seats) is an undesirable situation.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 7 of 15
Jay_B
in reply to: mathewkol
Anyone heard yet if Pressure Pipes can now be be DREF'd?
C3D 2018.1
C3D 2016 SP4
Message 8 of 15
mathewkol
in reply to: Jay_B
Yes they can.  See my post.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Civil-3D-2014-New-Features/td-p/3816516
Matt Kolberg
Message 9 of 15
troma
Sounds good Matt.  So if I'm in 2013 and another office sends me a 2014 file I can use everything in it, even if they were dref items not promoted into the file!  (Except pressure networks?)
Does the user in 2014 have to perform a "Save As" to 2013 for this to work?
Mark Green
Message 10 of 15
mathewkol
in reply to: troma
You can use everything in it within reason.  Objects that don't exist in 2013 will be rendered as proxy objects.  Some objects, including DREFs will have odd behavior, since the way they are used in 2014 has changed.
See here:
http://docs.autodesk.com/CIV3D/2014/ENU/index.html?url=filesCUG/topichead_0.htm,topicNumber=CUGd30e1...
No SAVEAS will be requyired, just open the file.
Matt Kolberg
Message 11 of 15
Neilw_05
Since XP is no longer supported, having this interoperability will allow for XP users with 2013 to work with newer version users for at least another year.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 12 of 15
dhenderhan
in reply to: Neilw_05
We recently upgraded a few computers to 2014 and were told it was completely backward compatible (except pressure networks, dref's) We are having issues opening 2014 dwg's in 2013.  no pressure networks, just point, surfaces, alignments, profiles, profile views, attached sheet set propoerties, multiple layouts, and attached images.  Comes up on the screen and immediately fatal errors.  Any ideas?  Doesn't matter wich computer, no 2014 dwg will open in 2013.
David E. Henderhan, PLS
Civil 3D 2023
Dell Precision 3660 - Windows 10 Pro 64-bit
Intel (R) RTX A2000
12th Gen Intel(R) Core(TM) i7-12700 2.10 GHz
128 GB ram
Message 13 of 15
klugb
in reply to: dhenderhan
We ran into some issues recently with 2013 files also after installing IDS 2014. After running a repair of 2013 our errors & FE's went away. Worth trying.
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Message 14 of 15
dhenderhan
in reply to: klugb
Thanks, but it didn't seem to fix it.
Civil 3D 2023
Intel (R) RTX A2000
128 GB ram
Message 15 of 15
hmartinez5
We are also experiencing the same issue when opening a 2014 file from 2013. The AutoCAD instance immediately fails.
Rail Community
