Distinguished Contributor
Doug_000
Message 1 of 7 (835 Views)
Internal Error: Eregen 8.0
835 Views, 6 Replies
03-26-2012 02:10 PM
Anyone seen this one before?
It happens in C3D 2012 when you create a multilead & then pan between 1st & 2nd leader pics. I have a few machines that will do it predictably & others that won't.
Employee
hgohel
Message 2 of 7 (814 Views)
Re: Internal Error: Eregen 8.0
03-29-2012 09:07 AM in reply to: Doug_000
Since you seem to have a way to reproduce this, it would be helpful to us to have a drawnig and the steps.  Could you please open a support case and submit the data/information?  Thanks.
Himanshu Gohel
Autodesk, Inc
civil_tech3
Message 3 of 7 (774 Views)
06-01-2012 02:52 PM in reply to: Doug_000
Recieved same error when trying to create a design alignment, first time recieving error.
Small pop up box titled Autocad Error and then reads Internal Error : Eregen 8 0
Only option is to click ok or red x, closes drawing regardless.
Have larger drawing with multiple corridors, intersections, surfaces, alignments, etc. first time recieving error, have been working with drawing for a few months now.
Employee
hgohel
Message 4 of 7 (762 Views)
06-04-2012 12:19 PM in reply to: civil_tech3
We have filed defect 1423140 for a specific case of a crash with a similar error message that occurs while grip-editing profiles.
If you have reproducible steps for any other cases, please submit a drawing and the steps so that we can verify if it is the same issue or something different that we need to investigate.
Himanshu Gohel
Autodesk, Inc
Employee
hgohel
Message 5 of 7 (720 Views)
07-03-2012 12:40 PM in reply to: hgohel
Civil 3D 2012 Update 2 includes a fix for DID 1423140 mentioned above.  Hope that helps.
Himanshu Gohel
Autodesk, Inc
Active Member
PowerCAD98
Message 6 of 7 (553 Views)
02-01-2013 03:22 AM in reply to: Doug_000
I just recieved this error and yes I was grip editing a design profile. I'm pretty sure I have service pack 2 loaded but when i went to the link you provided it said page not found.
Yvonne
Employee
hgohel
Message 7 of 7 (535 Views)
02-01-2013 01:54 PM in reply to: PowerCAD98
SP2 for Civil 3D 2012 was replaced by C3D 2012 SP2.1 so the URL in that post isn't valid.  BTW, this defect has also been resolved in Civil 3D 2013 SP1.
Please verify that you do, in fact, have the service pack installed.  After that if you can still reproduce the error please open a subscription support case, submit your data and steps to reproduce so we can investigate futher.
Himanshu Gohel
Autodesk, Inc
