Civil 3D Forum
Interference Checks
2 REPLIES 2
165 Views, 2 Replies
Interference Checks
Is there a way to get the actual top of pipe / invert elevations at the
locations where an interference check is run using Civil 3d 2007?
Thanks!
2 REPLIES 2
Not that I've found so far - and believe me I've looked. What I ended up with as a workaround is bringing the crossing pipes into a profile view and then using a profile view label to grab the elevation by snapping to the pipe. Inefficient, error-prone, and not dynamic I admit, but it gets the information you need.
HTH,
stephanie
hey how about being able to add interference objects to a profile view - as for pipe network parts. Like um, plot every crossing pipe within x metres (user defined x). There is a wishlist around here somewhere.....
Rail Community
