Distinguished Contributor
bigmaz
Message 1 of 3 (389 Views)
Integrating structures into Civil 3D
389 Views, 2 Replies
11-16-2011 02:12 AM
Hi guys
I am creating a drainange drawing with Civil 3D.  first of all, I was wondering about headwalls.  I have a few winged headwalls I need to integrate into my pipe network.  Reading about, it says that Civil 3D 2012 has winged headwalls as part of the structures library in the pipe network section, but I cannot find them, only rectangular headwalls.  I also have a custom size headwall we have designed, how would I put that in, would I just model it up as a 3D solid in autoCAD, and then how would I paste it into my final surface model?  Also, We have basins at the end of our drainage ditches, which is basically a square basin made up of gabion baskets, again, will I create it as a 3D solid in autocad?  Hope this all makes sense :smileytongue:
Martin
*Pro
dgordon
Message 2 of 3 (379 Views)
Re: Integrating structures into Civil 3D
11-16-2011 05:38 AM in reply to: bigmaz
if all you need to see is contours draw correctly to show a 2d top down view, then 3d solids are not necessary and a waste of time.
a couple break lines strategically placed is all you need to get the job done with a winged headwall.   it's similar to constructing a retaining wall with two break lines.   One for ground at  top of wall and one for ground at bottom of wall.
the contours don't care if a retaining wall is above the ground by a foot or 10 feet.
gabion baskets are below ground, so only the top of them needs to be modeled for surface contours.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
bigmaz
Message 3 of 3 (375 Views)
11-16-2011 05:57 AM in reply to: dgordon
Great, thanks for your help :smileyhappy:
