AutoCAD Civil 3D General Discussion
*alex
Message 1 of 5 (65 Views)
installation problem
65 Views, 4 Replies
10-28-2003 02:26 AM
when i installed civil 3d and try to run it is says i must aurthorize LDD4.
Ldd4 has been authorized and works fine. What can I do to get civil 3d to
work?
thanks, alex
*cwitzel
Message 2 of 5 (65 Views)
Re: installation problem
10-28-2003 02:54 AM in reply to: *alex
Is your LDD a network install?
If so you need to network install Civil 3D also.
Conan Witzel
*alex
Message 3 of 5 (65 Views)
Re:
10-28-2003 06:09 AM in reply to: *alex
It was but i uninstalled it and made it stand alone.
"cwitzel" wrote in message
news:F12A5A799EBE9C05B5F4045C4AC66977@in.WebX.maYIadrTaRb...
> Conan Witzel
*Belcher, Steve
Message 4 of 5 (65 Views)
Re:
10-28-2003 09:57 PM in reply to: *alex
Check out my 10/23 post. I had the same problem, but when I installed as
network install everything worked fine. I'm betting that when you
uninstalled LD 2004 you didn't wipe out all the local files and folders
associated with it. When you reinstalled, some of the old got mixed with
the new install and the software still thinks its a network install. Try
shutting down the LM and see if you can run LD 2004 by itself. If you can't
then you need to unistall LD 2004 and delete all folders and files
associated with it, then reinstall. This is just a guess. Hope it works
for ya!
"alex" wrote in message
news:smileyvery-happy:C8DCA7E86C19E4E6543E8F800FCD51D@in.WebX.maYIadrTaRb...
> > Conan Witzel
Distinguished Contributor
mscacco
Message 5 of 5 (65 Views)
10-29-2003 12:46 PM in reply to: *alex
you may have implied this in your message, but do you have Civil Design 2004 (or Civil Series) installed on the computer? Civil 3D requires Civil Design, not just Land
Mark Scacco
Announcements
Need installation help?
