I am in the process of installing the Ultimate Building Design Suite 2015. It failed at the Revit installation twice. I am attaching the installation log. Kindly review and assist
Adrian
It is failing on BIM360 Add-in.
I would recommend that you install the suite without checking this option. That should get the portions that you want installed and working. Afterwards, if you think you need BIM360, you can try to install it and see if it still fails.
Install Autodesk® BIM 360™ Add-in for AutoCAD® 2015 Failed Installation aborted, Result=1603
