Installation & Licensing
Installation of Ultimate Building Design Suite Failed
1 REPLY 1
232 Views, 1 Reply
I am in the process of installing the Ultimate Building Design Suite 2015. It failed at the Revit installation twice.  I am attaching the installation log. Kindly review and assist
Adrian
1 REPLY 1
TravisNave
It is failing on BIM360 Add-in.
I would recommend that you install the suite without checking this option.  That should get the portions that you want installed and working.  Afterwards, if you think you need BIM360, you can try to install it and see if it still fails.
Install	Autodesk® BIM 360™ Add-in for AutoCAD® 2015	Failed	Installation aborted, Result=1603
Autodesk Forums:
Administrator Productivity
