Civil 3D Forum
Insertion point problem
5 REPLIES 5
377 Views, 5 Replies
I have been trying to simply insert points in a .csv file (PNEZD).  The foints are taken SPC systems and elevations are in feet.  I am using the imperial english template with no conversions.  When i import the points from a file the points come in in the correct position but the elevation is in meters insted of feet!
Please advise
5 REPLIES 5
AllenJessup
Check your Point Label Style to be sure that someone didn't accidentally change it to Meters in the template. Not saying that's the problem. But it's the first and easiest to look at.
Allen Jessup
Allen Jessup
CAD Manager - Designer
jporter
Can you post a the point file so we can test on our end? Does this happen with the standard Civil 3D template as well as your own?
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
in reply to: jporter
Yes it does happen when i bring them in the default acad template
BrianHailey
Comes in fine for me. Can you post your drawing as well? You can strip all linework and C3D objects out of it if you want.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
jporter
in reply to: BrianHailey
It came in fine for me as well. All the elevations appeared as they do in the CSV file.  However, when I changed the drawing units to meters and then imported the points they were in the 3000 range elevations.  Is your template set up in meters and you just didn't know it?
Jason Porter
www.asti.com
Rail Community
