Hi every one
I have a problem inserting my data ( station,offset ) to an alignment with station equation >>>
the result not correct he ignore the distance of the station equation (( in my case 20 m ))
Hisham Fawzy
Civil 3d Certified Professional | Civil 3d Instructor
https://www.youtube.com/HishamFawzy
If you use the 'SO station offset transparent command you should be getting the Duplicate Station Selection dialog box which allows you to select the appropriate station value.
Thank you for reply
1. I tried to use the 'SO station offset transparent command but there no Duplicate Station Selection dialog box came out ..
2. I need it to get my data from file in this case i have to choose import from file so 'SO station offset transparent command will not be useful here
see the attached file if you can ,,
Hisham Fawzy
