Civil 3D Forum
Inserting "+" for the Station Column when generating .xml volume reports
6 REPLIES 6
mramseur
367 Views, 6 Replies
I currently have Civil 3D 2013.
When I generate .xml volume reports along a station line, a "+" sign is not shown for the station labels under the Station column in the xml table report (see PDF attachment).  Is there anyway for the volume report to insert a "+" in the correct postion for the station labels?
Thank you.
6 REPLIES 6
Jay_B
in reply to: mramseur
The stationing plus character on the Toolbox>Reports Manager>Corridors>Volume Report
is controlled by the Ambient Settings but could be overridden by Alignment Feature Settings.
Your Format may be set to "Decimal" change it to "Station Format".
Settings Tab of Toolspace>Right click on drawing name>Edit Drawing Settings>Ambient Settings>Station
If not Ambient settings, check here:
Settings Tab of Toolspace>Right click on "Alignment">Edit Feature Settings>Station.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
mramseur
in reply to: Jay_B
Well, not at all.  I checked those settings and they were set the same as what you showed.
It may have something to do with the .xsl program.
andrewpuller3811
Check the report settings.
Toolbox tab of the Toolspace palette -> very top left, click the toolbox. If you wait long enough, a tool tip will appear "Press this button to edit the Report Settings."
See the attached image.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
mramseur
in reply to: andrewpuller3811
Nope, it didn't change the station format in the volume report settings.
It was left in the ##+## format before in the toolbox settings anyway.
Thanks though.
Jay_B
Try posting your drawing here for someone to take a look.
C3D 2018.1
C3D 2016 SP4
mramseur
in reply to: Jay_B
Here is another PDF (see attachment) of the volume report showing what it looks like under the Station column.
Rail Community
