I currently have Civil 3D 2013.
When I generate .xml volume reports along a station line, a "+" sign is not shown for the station labels under the Station column in the xml table report (see PDF attachment). Is there anyway for the volume report to insert a "+" in the correct postion for the station labels?
Thank you.
The stationing plus character on the Toolbox>Reports Manager>Corridors>Volume Report
is controlled by the Ambient Settings but could be overridden by Alignment Feature Settings.
Your Format may be set to "Decimal" change it to "Station Format".
Settings Tab of Toolspace>Right click on drawing name>Edit Drawing Settings>Ambient Settings>Station
If not Ambient settings, check here:
Settings Tab of Toolspace>Right click on "Alignment">Edit Feature Settings>Station.
Well, not at all. I checked those settings and they were set the same as what you showed.
It may have something to do with the .xsl program.
Check the report settings.
Toolbox tab of the Toolspace palette -> very top left, click the toolbox. If you wait long enough, a tool tip will appear "Press this button to edit the Report Settings."
See the attached image.
Nope, it didn't change the station format in the volume report settings.
It was left in the ##+## format before in the toolbox settings anyway.
Thanks though.
Here is another PDF (see attachment) of the volume report showing what it looks like under the Station column.
