Civil 3D Forum
Inserting points with latitude and longitude
1 REPLY 1
397 Views, 1 Reply
I have a job where I have to locate over 200 water wells on a USGS map in Pennsylvania. I have a list of the wells from the state but the coordinates are in latitude and longitude. I can enter these points one at a time using the geodetic calculator but this is very time consuming. Does anybody know how to import all these points in one step?
1 REPLY 1
in reply to: 40032831983
This applies to Land Desktop as I do not use Civil 3D, but I am sure the procedure is similar. If the points are in a comma delimited ASCII file, add a field to the file that identifies the coordinate system (LL84 for example) and then when importing the file into Land Desktop, select the option to perform a coordinate transformation. LDT will look for the field that identifies the coordinate system of the import file and perform the transformation. Please review the help files for performing coordinate transformations during import. "rmkeen" wrote in message news:21693444.1103037068651.JavaMail.jive@jiveforum2.autodesk.com... >I have a job where I have to locate over 200 water wells on a USGS map in >Pennsylvania. I have a list of the wells from the state but the coordinates >are in latitude and longitude. I can enter these points one at a time using >the geodetic calculator but this is very time consuming. Does anybody know >how to import all these points in one step? >
Rail Community
