New Member
jfletter
Message 1 of 10 (3,570 Views)
Inserting Excel Tables into Autocad Civil 3D 2013
3570 Views, 9 Replies
10-14-2012 08:17 AM
Has anyone tried to insert Excel tables into 2013 3D?  It worked fine in 2012 but we just upgraded to 2013 and it no longer works.  We get an error message that Excel is not supported.  Is this a new feature or a bug?  Also, our old drawings with the table already inserted does not plot normally.  The table characters print at diffent sizes.
BrianHailey
Message 2 of 10 (3,563 Views)
Re: Inserting Excel Tables into Autocad Civil 3D 2013
10-14-2012 09:12 AM in reply to: jfletter
What method are you using to insert the table?
Brian Hailey
CAD-1.com
My Blog
Joe-Bouza
Message 3 of 10 (3,548 Views)
10-14-2012 01:27 PM in reply to: BrianHailey
Hi Brian, Is OLE or Data linking no longer supported?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
klugb
Message 4 of 10 (3,536 Views)
10-14-2012 03:43 PM in reply to: jfletter
Can yo post what version of Excel, or even better post the Excel file so we can test it?
Bruce Klug
AutoCAD Expert Elite
AutoCAD Civil 3D 2014 Certified Professional
Infrastructure Design Suite 2014 (SP2)
Testing Civil 3D 2015
Win 7 Pro, 64-bit
Joe-Bouza
Message 5 of 10 (3,532 Views)
10-14-2012 04:33 PM in reply to: klugb
Hi Bruce
I'm guessing you have not seen any anomolies
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
klugb
Message 6 of 10 (3,528 Views)
10-14-2012 05:22 PM in reply to: Joe-Bouza
I wouldn't say that, but I don't get any error messages.
I have had issues with not everthing coming over when I mess with the font size.
Excel 2010.
Bruce Klug
Win 7 Pro, 64-bit
LisaPohlmeyer
Message 7 of 10 (3,500 Views)
10-15-2012 05:50 AM in reply to: jfletter
I'm using MS Excel 2010, I copy the spreadsheet range, use Paste Special, paste it as an Excel link, no problem.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
Active Member
dschuler
Message 8 of 10 (3,294 Views)
11-20-2012 09:21 AM in reply to: LisaPohlmeyer
I'm having issues also.
I'm using MS Excel 2007.  Sometimes my drawing opens up and states that the OLE link is broken and somehow reverts the Excel file back to the previous state before it was modified.  Very frustrating!
It also only plots the OLE object 50% of the time.  I tried it with different printers, plotters, and even the same thing plotting to PDF.  Fixing to have to give up on the OLE technique.
David Schuler
Polywell Workstation
Intel Core i5-2400 @ 3.10 GHz
8 GB Ram
64 Bit Win7 OS
NVIDA GeForce GTS 450
Civil 3D 2013, SP1
Neilw
Message 9 of 10 (3,290 Views)
11-20-2012 09:25 AM in reply to: jfletter
Have you considered using a table object with the Data Link option?
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Valued Mentor
TerryDotson
Message 10 of 10 (3,268 Views)
11-20-2012 04:50 PM in reply to: Neilw
That is a much better approach than OLE, but if your spreadsheet isn't simple it can make a mess.
http://www.dotsoft.com/files/xl2cad-vs-tables.gif
