I am a fairly new user to C3D so this may seem simple.
Can I insert a point on an alignment at a particular Station?
Gary E. Gaiotti
Designer III
MICHAEL BAKER Jr. Inc
Yes you can use the point command and next use the station offset 'SO transparent command:
1. select an alignment,
2. set the chosen station,
3. set the offset
Do you mean a COGO point or an angle point? To insert a deflection point (PI), select the alignment, RT click (or go to the contextual Ribbon) and select Edit Geometry. There you will see a tool to insert a PI.
