Civil 3D Forum
Inserting a block deletes points with point style with same block
7 REPLIES 7
Message 1 of 8
Topher5000
393 Views, 7 Replies
We're using C3D 2013 SP2.  The survey company we use uses point styles to show the blocks.  Say they shoot a catchbasin.  Instead of inserting the block, the point shows up as the block.
I did a field check & needed to insert a missed CB.  When I inserted the block, the other points that were CBs disappeared.  I had to insert the block, copy it the clipboard, undo the insertion & then paste the block in.  It did this on other drawings & other blocks.
Any ideas why it would do this?
7 REPLIES 7
Message 2 of 8
troma
in reply to: Topher5000
I bet the block you're using for the catchbasin is different but has the same name as the one they're using in the point style. Did you get asked if you wanted to redefine the block when you inserted yours? If a block is similar but 1000 times smaller, when you redefine it in the drawing it could make all the current ones in the drawing 1000 times smaller, thus disappearing to the naked eye.
Mark Green
Working on Civil 3D in Canada
Message 3 of 8
Topher5000
No, I'm inserting the block that the point style uses & is already in the drawing.
Message 4 of 8
troma
I should stop betting.
Mark Green
Message 5 of 8
Joe-Bouza
in reply to: troma
thats funny
Your Name
Message 6 of 8
Joe-Bouza
what happens if you copy a point?
Your Name
Message 7 of 8
Topher5000
in reply to: Joe-Bouza
It creates a duplicate point & asks if it should be renumbered.  The other points don't disappear though.
Message 8 of 8
Joe-Bouza
Right. So give it a number well beyond the numbers in the surveyors database and get a cup of coffee 🙂
Your Name
Rail Community
