Here is another dumb question, can you put two vertical curves back to back without a tangent inbetween? one of our supervisors claims Microstation could do two vertical curves one right into the next without a tangent.
Thanks!
Compound or reverse curves in profile...hmm
Grip edit is the only way I know to accomplish this...To my knowledge tangents are a vertical curve definition parameter.
Yes you can. It's about the same workflow as Microstation. Just abandon PVI thinking and transition to entity based profiles.
http://www.screencast.com/t/gjtdaNCys2L1
Christopher
However, labeling a reverse verticle curve can be tricky. You'll need a couple of sets of special label styles so you don't have overlaping labels at the common bvc/evc.
Reid
The method I use is to put a very short tangent in between, say .001'. You can't see it, you just have to delete one of the overlapping labels. An added bonus if your standards call for it is you get the grade between the pvi's of each VC.
