Solved by Jeff_M. Go to Solution.
You can get to where Jeff is talking about by using the command, 'XR', and changing the type to Image in the dropdown at the top left of the window.
XREF. There is a dropdown menu in the upper left corner that you can change from "Dwg" to "Image".
Directly dragging the .jpg file from windows explorer to your model (or paper) space also works.
AK, I haven't been able to get the drag and drop functionality to work in any of the 2014 products I have installed. C3D, RASTER DESIGN, MAP, or plain AutoCAD. I can use the image or xref commands but it would be nice to just drop in non-georeferenced images. Is there a variable to enable drag and drop?
