Civil 3D Forum
insert osm file
5 REPLIES 5
14899 Views, 5 Replies
insert osm file
Hello everybody
how can i insert open street map file (osm) in autocad civil 3d 2012.
thanks
5 REPLIES 5
antoniovinci
You can't directly, so open the .OSM file in Qgis, then "save as" DXF format.
in reply to: antoniovinci
Thank u for your answer
But how can i open it in qgis program i download it and i dont find anyway to open the .osm file.
thanks
antoniovinci
@Anonymous wrote:
I dont find anyway to open the .osm file
CTRL-SHIFT-V => BROWSE => OPEN
Murph_Map
Try connecting to it as WMs connection.
Simply add a new WMS layer in Display Manager:
Data > Connect to Data > Add WMS Connection
  1. Add http://wms.latlon.org/?layers=osm and version as 1.1.1
  2. Cick Connect
  3.  Click Login
  4.  Check OpenStreetMap mapnik
  5. Click Add to Map
Murph
Supporting the troops daily.
TerryDotson
If you were to consider third party add-ons, MapWorks Base will import .OSM files directly into Civil3D (or plain AutoCAD).  The files are in lat/long and are projected to a designed plane system assigned to the current drawing.
Rail Community
