Hello
Info : the SP 1 for CIVIL 2015 is available
Patrice BRAUD
Solved by braudpat. Go to Solution.
Hi Jeff,
That link fails for me too. It's the correct link but doesn't work for me. I went to the 2015 SP 1 web page and it failed from there too. OOPS. Now it works. They must be doing updates.
Allen
Allen Jessup
CAD Manager - Designer
I didn't get the jist of this thread at first but if I understand correctly MapSp 2 is out and the C3d SP1 includes MapSp1, and this may cause an issue if you inadvertantly overwrite mapSP2, is the criptic message to be learned?
I became even more confused when I created a deployment for IDSP 2015 and saw this: whats up with that?
Your Name
Your Name
Joe,
You don't have to worry about overwriting Map 3D SP2 with Civil 3D SP 1. You can't apply the Map SP to Civil 3D. You can only apply it to the stand alone full version of Map 3D that comes with IDSP.
I wouldn't worry about the deployment. Create that and then try to install SP 2 for Map. That will tell the story. BTW When did you download the Map installation files? Before or after the SP was released?
Allen
Allen Jessup
Your Name
Your Name
