I need to make non-parallel feature lines into a grading object but the infill grading tool doesn't seem to want to work for it.
I make my closed feature line "loop" (at the correct grades/elevations), click on the "Create Grade Infill" icon, but when I select the area it doesn't even highlight... and when I click to select the area.... nothing happens.
suggestions?
Solved by david.zavislan. Go to Solution.
The feature lines need to be in the same site as the grading group.
I have the same problem. They are in the same group and that didn't solve the problem
