Once the visibility property is set to false, the only way I found to set
the property to true is via the alignment properties dialog, labels tab.
For example, if you turn off the BP label of the alignment, go into the
alignment props dlg, select the labels tab, select the Geometry Points label
type, and in the upper right corner of the dlg, click Reset. Bear in mind,
this will set all the visibility property of all labels of that type back to
true.
If there is a better way, please let me know!
wrote in message news:4989378@discussion.autodesk.com...
Another minor label issue...
If you grip an individual label, right click, and change it's visibility to
false(alignment station label say), how can this label be shown again? The
only way I can figure out how to restore the label is to re-apply the label.
Am I missing something?
If not, maybe a tall order but it would be nice if we could have a
non-plotting marker similar to the pin label toggle that could be selected
to restore the visibility of individual labels that have had their
visibility changed to false.
Inevitably with several labels we will need to suppress and then redisplay
the display of individual labels for finished drawing production.
