StormCAD can read the Land Desktop pipeworks database directly. Pipes can
be "drafted" in LDT, the db opened in StormCAD, run through an event, and
the pipes re-drawn in LDT - showing the HGL.
StormCAD V8 XM Edition runs on C3D 2008 - it simply adds the StormCAD menu
so your workflow doesn't really change. Pipes can be "drafted" in C3D,
exported via LandXML (you will have to do some cleanup as C3D's export to
LandXML doesn't accomodate for any outlet structures - any event you run in
StormCAD will appear to be caught in a loop because nothing will appear to
drain - I have less hair because of this). StormCAD work can then be
exported back to C3D via LandXML, the existing network will be updated -
again, you'll have cleanup.
The kicker is, you don't necessarily "need" to export your Haestad work via
LandXML to C3D. StormCAD can draw 'decent' looking pipe runs (in plan and
profile). Granted, the work won't be C3D dynamic, but depending upon your
scenario, it may not need to be...
sm
Scott McEachron
DCCADD Dallas - Fort Worth
http://c3dpavingtheway.blogspot.com/
"ralph sanchez" wrote in message
news:5707295@discussion.autodesk.com...
We'd like to be able to design storm sewer using StormCAD, export the data
to LandXML, and then import it into Civil 3D. In Civil 3D, it would be easy
to create a profile that can be massaged, via styles, to look the way our
agencies dictate. The only problem is, as far as I know, there is no method
of showing HGL in Civil 3D profiles. How is everyone else getting around
this?
Alternately, there doesn't appear to be a method to get data from StormCAD
into Land Desktop, as Land Desktop's LandXML support does not include pipe
runs.
Ralph Sanchez
www.texupport.net
