Civil 3D Forum
Incorrect South Azimuth direction values after editing Alignment Curve XSL
2 REPLIES 2
kbarnettza
530 Views, 2 Replies
Civil 3D 2014.
The default reports provided in the Toolbox Report Manager cannot be used - as they are - in South Africa. And... the Country Kit has not attended to this problem.
So, I tried to edit it myself... Looks like I made a small mistake somewhere, please help.
In the "Alignment Curve.xsl" I replace Bearing with "South Azimuth", like this:
<td>Bearing:</td>
<xsl:variablename="angle"select="landUtils:GetLineDirection($pos)"/>
<xsl:variablename="Bearing">South Azimuth</xsl:variable>
An example report, looks like this:
Alignment: Road 1 Description:
Tangent Data
Length:60.441Bearing:227° 01' 39.6530"
Circular Curve Data
Delta:88° 06' 57.0898"Type:RIGHT
Radius:12.500
Length:19.224Tangent:12.096
Mid-Ord:3.517External:4.894
Chord:17.385Bearing:358° 54' 51.8021"
Tangent Data
Length:52.804Bearing:314° 51' 23.2572"
Circular Curve Data
Delta:90° 57' 40.3710"Type:LEFT
Radius:12.500
Length:19.845Tangent:12.711
Mid-Ord:3.736External:5.328
Chord:17.825Bearing:269° 39' 46.5573"
Tangent Data
Length:103.845Bearing:224° 10' 56.3718"
Two of the bearing/direction values are incorrect (the inner ones), here is the correct values:
Please indicate where I went wrong ... or what I have missed.
The DWG is attached.
Thx..
Kevin.
2 REPLIES 2
Jeff_M
in reply to: kbarnettza
Which xsl file did you edit? I don't see the lines you show in the Alignment Curve.xsl  Scratch that. I see that they didn't use a global variable for this so need to change it in a number of lines. The problem is in the Number_Formatting .xsl Scroll down the the Direction Formatting, then to the South Azimuth section. The final "else if" needs to be changed to this:
else if(dirNum < 360 && dirNum > 270)
var adjDir = 360 - (dirNum - 270);
var dirStr = FormatDirectionWithUnit(adjDir , precisionStr, roundingStr, unit);
return dirStr;
Jeff_M, also a frequent Swamper
kbarnettza
in reply to: Jeff_M
Thank Jeff, probably the most diligent observer participating in the Autodesk forums. You save me yet again. I hope I am not the only user that appreciates and can implement the solutions you provide.
Here's hoping life is treating you extra well...
Take care..
Rail Community
