Civil 3D Forum
Incompatibility C3D 2013 and 2014
6 REPLIES 6
olgierd44
419 Views, 6 Replies
I have problem with compatibility this two versions of civil 3D. Files created in C3D 2013 then modified in 2014 don't want to open in C3D 2013. Files contain many civil objects: shortcuts, corridors. During opening occurs fatal error.
There is no problem with files which were created in C3D 2014 from the begining only modified in C3D 2014.
If anybody know what could make this error I'll be appreciate for help.
6 REPLIES 6
Alfred.NESWADBA
in reply to: olgierd44
welcome @forums.autodesk.com !
>> don't want to open in C3D 2013. [...] During opening occurs fatal error.
Have you tried to run _AUDIT before saving in 2014 ... or to open the file with _RECOVER (or _RECOVERALL) with 2013 instead of using the default _OPEN command?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
olgierd44
in reply to: Alfred.NESWADBA
It doesn't work.
AllenJessup
The only reference I've found is that Pressure Pipe DRefs in 2014 aren't supported in 2013. Other than that. If you are on Subscription you should start a Service Request in the Subscription Center.
Allen Jessup
Allen Jessup
CAD Manager - Designer
Alfred.NESWADBA
>> It doesn't work.
Command _AUDIT does not work in 2014?
- alfred -
Alfred NESWADBA
olgierd44
Command AUDIT works but doesn't help to soleve my problem. I was trying use command _recover from level of C3D 2013 and command AUDIT from level C3D 2014. Unfortunetly files are availbe to open only in C3D 2014. Users which have acces only to C3D 2013 are blocked.
Alfred.NESWADBA
Can you delete all from that drawing (a copy of it) and try it again? If that also fails then upload this defect minimized drawing here so we can look into it.
- alfred -
Alfred NESWADBA
Rail Community
