10 Kudos
Post 1 of 22
Include Text in Expression.
733 Views, 21 Replies
12-21-2012 06:17 AM
I need include one text in Expression for AutoCAD Civil 3D
My Expression: IF({Asymmetric Length 1}>1,({K Value}/{Profile Curve Length}*{Asymmetric Length 1}),-1)
I need this Expression: IF({Asymmetric Length 1}>1,(k1:{K Value}/{Profile Curve Length}*{Asymmetric Length 1}),-1)
K1 is Text for indicate the result for expression. I can not include this text in outside label because, while =-1, the label is invisible.
Adriano Oliveira
MaxiCAD Informática
www.maxicad.com.br
Hello Adriano
I don't think so, because we have to use the condition for text heigh assignment you'll need an expression for both
308 Kudos
Post 2 of 22
Re: Include Text in Expression.
12-21-2012 09:30 AM in reply to: Adriano_cad
Are you trying to plug a result of -1 in as a text height?
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
10 Kudos
Post 3 of 22
12-21-2012 09:35 AM in reply to: tcorey
No. The expression already does what I need. But I want the same expression I can have a text.
Adriano Oliveira
MaxiCAD Informática
www.maxicad.com.br
308 Kudos
Post 4 of 22
12-21-2012 11:17 AM in reply to: Adriano_cad
Rather than try to add text in the expression, you can add text to the label style.
Tim Corey, Owner
Redding, CA
10 Kudos
Post 5 of 22
12-21-2012 11:46 AM in reply to: tcorey
Hi.
Yes I know.
 But I need to make the text value K1 be invisible whenever the expression result is -1. So can not be included on the label, because if you stay in the label text value K1 will not be invisible.
Adriano Oliveira
MaxiCAD Informática
www.maxicad.com.br
308 Kudos
Post 6 of 22
12-21-2012 12:49 PM in reply to: Adriano_cad
Make two expressions. Make two components in your label style.
The expression that evaluates to -1 should return a positive value (text height) if true and 0 if false. Build your label component, adding the additonal text KB, and for Text Height, click the drop down list within Text Height and pick this expression.
The other expression should return positive if the result is not -1 and 0 if it is. Add another component to the label style, this time without the extra text KB. In the Text Height drop down, pick this expression.
Each expression will force a component to have a positive text height or 0.
Tim Corey, Owner
Redding, CA
329 Kudos
Post 7 of 22
12-21-2012 02:22 PM in reply to: Adriano_cad
Tim has it. You cannot have conditional strings, but you can have conditional expression to set the text height like the ubiquitous cut and fill labels that get bandied about here
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
10 Kudos
Post 8 of 22
12-21-2012 04:42 PM in reply to: Joe-Bouza
Hello everyone.
The problem is as follows:
The expression rode doing what I need. But I need to include a label before the dynamic expression. Eg
If the expression result is positive then the label informs K1 = value of the expression.
If the expression result is negative then the label is not displayed.
The expression profile for curves:  IF({Asymmetric Length 1}>1,({K Value}/{Profile Curve Length}*{Asymmetric Length 1}),-1).
Adriano Oliveira
MaxiCAD Informática
www.maxicad.com.br
267 Kudos
Post 9 of 22
12-21-2012 08:01 PM in reply to: Adriano_cad
As others have stated, an expression will ONLY return a number. You cannot get an expresson to return text in any way shape or form. Can't be done. No way to do it. Impossible.
The only workaround we currently have is to return a value for the height of the text. If the expression is true, return a valid height for the label component. If the expression is false, return a really really small height for the text. Now use that in the height field for the label component.
Brian Hailey
CAD-1.com
My Blog
10 Kudos
Post 10 of 22
12-21-2012 08:17 PM in reply to: BrianHailey
I already know that an expression can only return number. My appointment was for friends to see if some had already found a solution for this.
Thank you, all.
Adriano Oliveira
MaxiCAD Informática
www.maxicad.com.br
