Civil 3D Forum
Include Text in Expression.
27 REPLIES 27
Message 1 of 28
Adriano_cad
4183 Views, 27 Replies
I need include one text in Expression for AutoCAD Civil 3D
My Expression: IF({Asymmetric Length 1}>1,({K Value}/{Profile Curve Length}*{Asymmetric Length 1}),-1)
I need this Expression: IF({Asymmetric Length 1}>1,(k1:{K Value}/{Profile Curve Length}*{Asymmetric Length 1}),-1)
K1 is Text for indicate the result for expression. I can not include this text in outside label because, while =-1, the label is invisible.
Adriano Oliveira
Diretor Soluções BIM MaxiCAD
MaxiCAD Soluções e Educação BIM.
Facebook | Twitter | LinkedIn
some text
27 REPLIES 27
Message 2 of 28
tcorey
in reply to: Adriano_cad
Are you trying to plug a result of -1 in as a text height?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 28
Adriano_cad
in reply to: tcorey
No. The expression already does what I need. But I want the same expression I can have a text.
Adriano Oliveira
some text
Message 4 of 28
tcorey
Rather than try to add text in the expression, you can add text to the label style.
Tim Corey
Redding, CA
Message 5 of 28
Adriano_cad
in reply to: tcorey
Hi.
Yes I know.
 But I need to make the text value K1 be invisible whenever the expression result is -1. So can not be included on the label, because if you stay in the label text value K1 will not be invisible.
Adriano Oliveira
some text
Message 6 of 28
tcorey
Make two expressions. Make two components in your label style.
The expression that evaluates to -1 should return a positive value (text height) if true and 0 if false. Build your label component, adding the additonal text KB, and for Text Height, click the drop down list within Text Height and pick this expression.
The other expression should return positive if the result is not -1 and 0 if it is. Add another component to the label style, this time without the extra text KB. In the Text Height drop down, pick this expression.
Each expression will force a component to have a positive text height or 0.
Tim Corey
Redding, CA
Message 7 of 28
Joe-Bouza
Tim has it. You cannot have conditional strings, but you can have conditional expression to set the text height like the ubiquitous cut and fill labels that get bandied about here
Your Name
Your Name
Message 8 of 28
Adriano_cad
in reply to: Joe-Bouza
Hello everyone.
The problem is as follows:
The expression rode doing what I need. But I need to include a label before the dynamic expression. Eg
If the expression result is positive then the label informs K1 = value of the expression.
If the expression result is negative then the label is not displayed.
The expression profile for curves:  IF({Asymmetric Length 1}>1,({K Value}/{Profile Curve Length}*{Asymmetric Length 1}),-1).
Adriano Oliveira
some text
Message 9 of 28
BrianHailey
As others have stated, an expression will ONLY return a number. You cannot get an expresson to return text in any way shape or form. Can't be done. No way to do it. Impossible.
The only workaround we currently have is to return a value for the height of the text. If the expression is true, return a valid height for the label component. If the expression is false, return a really really small height for the text. Now use that in the height field for the label component.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 10 of 28
Adriano_cad
in reply to: BrianHailey
I already know that an expression can only return number. My appointment was for friends to see if some had already found a solution for this.
Thank you, all.
Adriano Oliveira
some text
Message 11 of 28
Joe-Bouza
Yes, there is a solution, as stated
Your Name
Your Name
Message 12 of 28
Adriano_cad
Hello
How are you?
Yes, your idea is ok.
I did so and it was good. I like to have a single expression for all.
When I wrote the words already knew he could not contain text, but I decided to take the opnion of all to see if anyone did.
Thanks.
Adriano Oliveira
some text
Message 13 of 28
Joe-Bouza
Hello Adriano
I don't think so, because we have to use the condition for text heigh assignment you'll need an expression for both
Your Name
Your Name
Message 14 of 28
Adriano_cad
Exactly, that's what made an expression for each label, so the control was dynamic.
thank you
Adriano Oliveira
some text
Message 15 of 28
Adriano_cad
in reply to: tcorey
No. The expression already does what I need. But I want the same expression I can have a text -- *Adriano Oliveira* 51.9167-8397 adriano.cad@gmail.com / suporte@maxicad.com.br Authorized Author / Autodesk Authorized Instructor / Consultor de Aplica??o Pr?mio Instructor Quality Award pela Autodesk Inc Suporte MaxiCAD Inform?tica www.maxicad.com.br www.maxicad.com.br/blog http://br.linkedin.com/pub/adriano-oliveira/42/914/774
Adriano Oliveira
some text
Message 16 of 28
Adriano_cad
in reply to: tcorey
Hi. Yes I know. But I need to make the text value K1 be invisible whenever the expression result is -1. So can not be included on the label, because if you stay in the label text value K1 will not be invisible. -- *Adriano Oliveira* 51.9167-8397 adriano.cad@gmail.com / suporte@maxicad.com.br Authorized Author / Autodesk Authorized Instructor / Consultor de Aplica??o Pr?mio Instructor Quality Award pela Autodesk Inc Suporte MaxiCAD Inform?tica www.maxicad.com.br www.maxicad.com.br/blog http://br.linkedin.com/pub/adriano-oliveira/42/914/774
Adriano Oliveira
some text
Message 17 of 28
tcorey
Hello Adriano,
Could post a drawing for us to look at? That might help us bridge our language difference.
Best regards,
Tim
Tim Corey
Redding, CA
Message 18 of 28
Adriano_cad
in reply to: tcorey
Hello
I going send one drawing with situation.
Adriano Oliveira
some text
Message 19 of 28
troma
I think you just need one expression.
It needs to be desgined to return a zero for the case where you don't want the text to display.
It needs to be desgined to return your text height for the case where you do want the text to display.
(NB text height in drawing units.  I found this out: if I want 1.5mm text, I would type 1.5 in the text height box.  But if you're using an expression to set the text height it's 0.0015, because it reads it as metres.)
As others have said, use this expression as the text height for the componant " K1=<xxx> "
The entire componant will disapear in the case when the text height is zero.
I don't know if you will need other expression to change the size of the border around the text.
Mark Green
Working on Civil 3D in Canada
Message 20 of 28
Adriano_cad
in reply to: troma
HI,
The equation works, but when the component is not located on the curve is the value? '. Do you have any idea how to hide?
Adriano Oliveira
some text
Rail Community
