Civil 3D Forum
In Civil 3D 2012 - Style Edit > Display Tab... Can not collapse layer column?
7 REPLIES 7
Message 1 of 8
CADvisers
893 Views, 7 Replies
In Civil 3D 2012
See attached image.
This is happening on any object style that I try to edit.
In 2011 and 2013 it displays correctly on the same machine.
Any thoughts?
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
Tags (2)
7 REPLIES 7
Message 2 of 8
Wow, that's horrible.  I'm assuming if you move the slider bar all the way to the right you still don't find the end of the Layer column?
I rarely have time to post. If what I post helps please use Accept as Solution / Like when appropriate.
Check out my Civil 3d blog at: http://c3dk.com/
Message 3 of 8
I do see the end.  And it does display the rest of the columns, but can't slide the column back to normal size.
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
Message 4 of 8
johngordon6189
in reply to: CADvisers
when you slid to the end of the view and saw the other end of the header, did you try double clicking the line to pop it back?
John Gordon
CAD Manager/Survey Technician
C3D 2018/2020
Microstation
Windows 10
Message 5 of 8
CADvisers
in reply to: johngordon6189
Yes,  I tried.
It works fine on the Compnent Type and Visible columns, but the rest are locked down and way, way at the end.
I've tried right-clicking on the column headers, doubleclicking, and sliding.  Nothing!
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
Message 6 of 8
The 2012 profile style dialogue settings for the columns are stored in the registry here -
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-A000:409\Profiles\<<C3D_ANZ>>\Dialogs\AeccUiPpVbStyleDisplayProps\ColumnInfo]
replace <<C3D_ANZ>> with your active profile name.
The key AeccUiPpVbStyleDisplayProps:CListCtrl::1864 stores the values for the columns widths.
On my machine if I set the value to for the key to "0:1:" the column widths reset to the default widths.
If you can access the registry and set the value as above, this may fix your problem.
Of course the usual warnings about backing up the registry apply, etc.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 7 of 8
Thank you so very much Andrew!
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
Message 8 of 8
ctbailey
in reply to: andrewpuller3811
This solved my similar problem in Civil3D 2013 also. It at least got me in the correct "neighborhood" in the registry. Thanks!
_______
Craig T. Bailey, PE, LLS, PSM
Bailey Associates
www.bailey-associates.com
Rail Community
