Valued Contributor
CADvisers
Message 1 of 8 (559 Views)
In Civil 3D 2012 - Style Edit > Display Tab... Can not collapse layer column?
559 Views, 7 Replies
02-12-2013 01:02 PM
In Civil 3D 2012
See attached image.
This is happening on any object style that I try to edit.
In 2011 and 2013 it displays correctly on the same machine.
Any thoughts?
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
The 2012 profile style dialogue settings for the columns are stored in the registry here -
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-A000:409\Profiles\<<C3D_ANZ>>\Dialogs\AeccUiPpVbStyleDisplayProps\ColumnInfo]
replace <<C3D_ANZ>> with your active profile name.
The key AeccUiPpVbStyleDisplayProps:CListCtrl::1864 stores the values for the columns widths.
On my machine if I set the value to for the key to "0:1:" the column widths reset to the default widths.
If you can access the registry and set the value as above, this may fix your problem.
Of course the usual warnings about backing up the registry apply, etc.
Valued Contributor
brian.strandberg
Message 2 of 8 (542 Views)
Re: In Civil 3D 2012 - Style Edit > Display Tab... Can not collapse layer co
02-12-2013 01:58 PM in reply to: CADvisers
Wow, that's horrible.  I'm assuming if you move the slider bar all the way to the right you still don't find the end of the Layer column?
Valued Contributor
CADvisers
Message 3 of 8 (536 Views)
02-12-2013 02:01 PM in reply to: brian.strandberg
I do see the end.  And it does display the rest of the columns, but can't slide the column back to normal size.
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
Distinguished Contributor
johngordon6189
Message 4 of 8 (500 Views)
02-13-2013 12:27 PM in reply to: CADvisers
when you slid to the end of the view and saw the other end of the header, did you try double clicking the line to pop it back?
John Gordon
CAD Manager/Survey Technician
C3D 2012, C3D 2015
Eagle Point Surveyors Companion/Data Reduction/Civil 2010
Valued Contributor
CADvisers
Message 5 of 8 (491 Views)
02-13-2013 12:40 PM in reply to: johngordon6189
Yes,  I tried.
It works fine on the Compnent Type and Visible columns, but the rest are locked down and way, way at the end.
I've tried right-clicking on the column headers, doubleclicking, and sliding.  Nothing!
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
Distinguished Mentor
andrewpuller3811
Message 6 of 8 (480 Views)
02-13-2013 06:54 PM in reply to: CADvisers
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
Valued Contributor
CADvisers
Message 7 of 8 (475 Views)
02-13-2013 07:07 PM in reply to: andrewpuller3811
Thank you so very much Andrew!
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
ctbailey
Message 8 of 8 (48 Views)
07-31-2014 08:56 AM in reply to: andrewpuller3811
This solved my similar problem in Civil3D 2013 also. It at least got me in the correct "neighborhood" in the registry. Thanks!
__________
Craig T. Bailey, PE, LLS
Bailey Engineering
