my point names have letters in them. i wrote an xml file to import into civil3d and when i do, it renumbers them. for instance out of inroads the point name is "IP 0204 - 123", and when i import that into civil3d it comes in as "465446". is there something i can do to keep it as originally exported? it renames them to something completely different. i could possibly even do without the "IP" part but keep the "0204 - 123". there are 12000 points and i cant rename them by hand. i have exported other xml's out of there and had it work fine but they didnt have letters in the name.
thanks!
I believe Civil 3D only likes whole numbers for point numbers:
Can you possible make the point number a description instead and have the software automatically number them from 1 - ??? for you?
Just a thought,
MT,
Have you tried creating a Point File Format using Name instead of Point Number?
Dave
Dave Stoll
Las Vegas, Nevada
MT,
Where is the XML File coming from? Have you tried just importing the points with a CSV Point File Format that uses Name instead of Number?
Dave
Dave Stoll
Las Vegas, Nevada
