AutoCAD Civil 3D General Discussion
Member
BombthePeasants
Message 1 of 2 (341 Views)
Importing survey database points into drawing
341 Views, 1 Replies
12-13-2011 02:29 PM
I have a problem with the survey database. On occasion (as in, not every single instance), I will have an error when I go to "insert into drawing" my points. What will happen is only a small portion of them well import. I can delete the points from the drawing, re-attempt it, and usually on the 2nd time it will work, but on some occasions that won't work, either. Is this a bug with the program, or is there some step I'm missing? It seems to be a bug, because some days it works just fine, whereas other days, like today, it is very temperamental.
Help please,
ERIK
Valued Mentor
stacy.dunn
Message 2 of 2 (335 Views)
Re: Importing survey database points into drawing
12-13-2011 03:36 PM in reply to: BombthePeasants
It is a bug.  It will also occasionally happen with figures.  The best way I have found to avoid it is to highlight the list of points in the panorama and then right-click and insert into the drawing.
Stacy Dunn
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
