Civil 3D Forum
Importing Surface from 3d faces
3 REPLIES 3
268 Views, 3 Replies
I have a TIN surface defined by Acad 3d-faces from one of the "other" civil packages. What is the procedure for importing/transforming this dwg to a surface in Civil 3D-2006?
3 REPLIES 3
How about exporting to LandXML from the "other" civil package and then
import into Civil 3D?
wrote in message news:4907125@discussion.autodesk.com...
Mark,
Make a new surface, and then add the 3d faces to the surface inside of
"Prospector" Surface->definition->Drawing Objects. Select 3D Faces, you can
also maintain the edges from the faces so the DTM will match the triangles
directly.
Peter Funk
API Product Manager
Autodesk, Inc.
Thanks. That worked fine. Appreciate the help.
Mark
Rail Community
