When I attempt to import a PKT file from SAC, C3D crashes. Does anyone have any suggestions? This includes custom ones that I created as well as samples from the ADESK site.
Don Ireland
Engineering Design Technician
Since it wouldn't let me import the SA in to a Pallette, I attempted to import it into the catalog instead. After doing so, the catalog popped up--but the SA was NOT there. Guess what--the SA was on the pallette the was selected before I turned off the check box next to the option to save to the pallette. AND the name did NOT match the name that I had assigned to it in SAC. GRRR
Don Ireland
@doni49 wrote:Since it wouldn't let me import the SA in to a Pallette, I attempted to import it into the catalog instead. After doing so, the catalog popped up--but the SA was NOT there. Guess what--the SA was on the pallette the was selected before I turned off the check box next to the option to save to the pallette. AND the name did NOT match the name that I had assigned to it in SAC. GRRR
Well that seems to have just been a fluke. Now I can't get an SA to import at all (or at least I can't find it). See the following screen shot and you'll see what my dialog looked like when I imported the SA.
After importing the SA, the "Catalog" opened up and I see "New Catalog". But IT'S EMPTY (see the second screen shot).
Don Ireland
Does anyone know where the toolbox data is stored? I'm wondering if maybe I don't have enough rights to edit the toolbox and it's causing Acad to crash. But then again, it DID put the SA on the pallette at one point -- when I told it NOT to.
Don Ireland
Anyone have any ideas?
Don Ireland
I'm going to take pity on you because I hate it when no-one replies to me. But I have no idea whatsoever about SAC.
Mark Green
Working on Civil 3D in Canada
I am not sure why yours is crashing, but I would be willing to try it here as a test if you want to post your packet. Change it's extension to zip or you can't post it.
Don Ireland
I forgot to post yesterday.
The one named "ConditionalHorizontalOffsetAltSlope" is one that I created.
The other was downloaded from the Autodesk samples. BOTH (actually EVERY pkt) cause C3D to crash when I try to import to a tool pallette.
Don Ireland
Here's one that I just created a few min ago. Consists of two SurfaceLinks, two normal links and one shape.
When I attempted to import it, C3D crashed.
Don Ireland
I've continued to troubleshoot this on my own. It consistently crashes when I attempt to add the SA to a new pallette. But I found that if I let it add the SA to an existing pallette, it comes in fine.
Don Ireland
